Copy and Edit Asset (Asset Browser)
When creating a copy of an asset in your library using the copy function (seen below) it would be create if while completing that command you could start editing it without having to browse and find the newly published asset in your library.
It's a slightly backwards workflow to create a copy then have to find it within your library again to edit it, as almost every time we create a copy we want to make some kind of change to it so why not make this all part of the same command? Hopefully others would find this helpful too
3 Comments
robert.elsey
Make it an option within the right click menu. So there would be "Copy...", "Copy&Edit..." and "Edit..."
Logos_Atum
I like it. Usually when I need to change an asset I remove the write protection of the Factory Assets folder. That works for me for now.
Josh_Hudson97
Agree with @robert.elsey can't see any downsides to having all 3 options. But Copy and Edit in one click would be awesome. Hopefully something the Dev team could look to implement fairly easily as both buttons already exist independently, just need one that does it all in one click 🙌🙌
