Rendering pits in Factory
Logos_Atum
Advisor Advisor
Logos_Atum
Hello there,
when you place a pit there is a grey shadow indicating
the ground level. Can this be turned off? It´s not looking
good when rendering the layout.
Thanks in advance
Daniel
Dogs aren´t flammable.
adsk_loren
A solid floor is automatically created when you add a pit, which complicates things a bit. In Inventor, the floor visibility setting controls both the solid floor and the reference floor.
In Navisworks, you can turn off the reference floor in the application options.
Regards.
Loren
Loren
Logos_Atum
Hey Loren,
yes the floor is quite aggravating. I can turn it off but
if I do, the pit looks like a floating basin, which is not
very good.
Do I really have to do a sketch for the floor level and
turn off the floor in Factory then? It´s not very practical
I think.
Kind regards
Daniel
XuesongBai
Hi Daniel,
You just want get good shadow on the ground floor, right?
Why not open the floor part from disc in Inventor and assign great material to the floor part.
-Xuesong
Please mark as a solution if somehow I got it right.
Logos_Atum
Hello Xuesong,
yes it partly is because of the shadows but mainly
the grey tint on the floor level. I will consider your
suggestion and thanks !
Kind regards
Daniel
adsk_loren
Hi Daniel,
I came up with a workaround. Here are the basic steps:
  1. I created a new pit asset with the top face cut down by 1". This eliminates the appearance conflict between the floor and the top of the pit.
  2. I placed the new pit and turned off the floor visibilty.
  3. I added a copy of the floor (just drag and drop from the browser). Note that the new floor isn't in the Floor Objects folder and doesn't include the cutout for the pit.
  4. I created a sketch on the new floor (3D Model tab> New 2D Sketch) and projected the outside edges of the rim.
  5. I created an Extrusion that cut through the new floor. (turn off visibility for the pit first so it isn't included in the Extrusion feature)
  6. I used the Ground and Root command to align the floor with the origin (Assemble tab> Productivity panel> dropdown menu).
Loren
Logos_Atum
Hello Loren,
thank you so much. We will be trying out this solution
and I´ll get back to you as soon as we did. Thank you!
Kind regards
Daniel
