Hello guys,
i'm Alex, from an Autodesk partner gold re seller in Brazil. (Grapho Software)
I'm having a issue with the PA360, while doing some work with a customer here.
I need to set 2 operations to work at same time on the same processor, they need to start and end at same time, because the lot is set to 2 pieces or parts in the analysis. I know we have the "sequencial" check box, but seems that doesn't work. i'm sending a image.
Thank you all.
