I just upgraded my Factory Design software from 2017 to 2018 and when I open the new software, the Factory Tab is not loading in my AutoCAD Architecture 2018 software. Is there a fix for this?
Solved by raulcab. Go to Solution.
Solved by angela.cao. Go to Solution.
Hi Raul,
Thanks for asking and please pardon the delayed response!
Let's see if we can get it to show up through these steps:
See the image attached for details.
Hopefully that does the trick! Please share, if that does not help.
Angela Cao
Thank you, very much, Angela!
That solved the problem for AutoCAD Architecture and when I opened AutoCAD Mechanical it automatically downloaded the Factory Design Tab as well!
It worked perfectly.
Hi...
I'm having a similar problem. When editing a reference or block all of the save changes, etc. don't appear. Right now the only option is to explode and recreate block. The FactApplication doesn't appear anywhere after following your sequence. Can you help?
Jacquie
Hi Jacquie,
When you open the Control Panel, scroll down the list to make sure you have "Autodesk Factory Design Utilities for AutoCAD" installed.
Angela Cao
Hi Jacquie,
If you have access to the Product Design Collection, you would install it from the Autodesk Desktop App.
Here are some resources to help you get started:
Angela
