Creating designs with the skeleton approach is getting more used by Inventor users. This method often requires the use of skeleton (dummy) parts which drived the geometry, but they should be invisilble, reference parts themselves.
The skeleton parts is often solid models, and we use view representations to keep them invisible in inventor.
The problem is when an assembly is appended in Navisworks, everything seems to be visible. Including the skeleton part that might cover the whole design.
-Is it possible somehow to make Navisworks respect the active view representation? Or to select which view representation to be used in Navisworks?
It is very tedious to manually hide all these parts. Some designs will even have the skeleton inserted many many times in all subassemblies.
