Factory in several floors
Message 1 of 23
Hi, we are allways projecting high buildings with several floors (see attached files) but FDS is clearly not designed for that.
The problem is that I can't get the connection points to transfer through more than one assembly (see attached file) and I would like to make the assembly structure like in the sketch, so we can work more than one person on the project at the same time, for example one person on basement and one person on third floor.
How would you do this? Have I missed something, maybe a feature in FDS?
It is difficult to explain so please ask.
Best regards
Thomas Thomsen
Denmark
Replies (22)
Message 2 of 23
XuesongBai
Hi Thomas,
According to the snapshot, I noticed that is the multi-floor layout design, but each floor with different elevation, Correct?
As my experience, the elevation of each floor is determined by the 3D epuipment. So generally, as the start, the chief designer need to create the multiple floor and then assign each floor design to one person.
We can use FDS for this design. I like to discuss with you the details. Maybe, to have a online meeting is great.
-Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 23
I can't find anything about multiple floors (FDS 2014), so a little online help would be appreciated very much 🙂 . How do we do that, Teamviewer?
I think you have my email address.
B.r.
Thomas
Message 4 of 23
Maybe you can explain the method and I'll try what you suggest?
B.r.
THomas
Message 5 of 23
XuesongBai
Hi Thomas,
I think I have your email address.
One question to you, what is the first platform to start the multiple floor design? AutoCAD or Inventor?
-Xuesong
Message 6 of 23
Hi again,
We only use Inventor because AutoCAD is useless for these factory layouts. We make at lot of section views and AutoCAD can't show asset i 3D (from side).
- Thomas
Message 7 of 23
XuesongBai
Hi Thomas,
I sent to you the video of multi-floor layout with different elevations in factory Inventor.Please check your email and wait for your feedback.
-Xuesong
Message 8 of 23
IT WORKS...Thanks a lot!
I didn't know of the hidden sub-layout-button before this video 😉
Best regards
Thomas Thomsen
Message 9 of 23
XuesongBai
Nice to hear that is working for you.
-Xuesong
Message 10 of 23
...almost working.
I still can't transfer the connector from First Floor to Second Floor. It is working from Ground Floor (main assembly) to First or Second Floor.
-Thomas
Message 11 of 23
XuesongBai
Hi Thomas,
I see. So you need to use "Expose" command in factory Inventor to transfer the connectors that need to be consumed in the other sublayout.
-Xuesong
Message 12 of 23
Yes, exactly. From sub to sub.
- Thomas
Message 13 of 23
XuesongBai
So we can close the thread.
-Xuesong
Message 14 of 23
...but I can't get to work from sub to sub, only from main to sub or sub to main.
- Thomas
Message 15 of 23
XuesongBai
Hi Thomas,
Have you expose the connectors in each sub?
If possible,could you please send me a snapshot of the layout design?
-Xuesong
Message 16 of 23
I made a small video of what I trying to do. The two upper floors are sub-layouts and I can't transfer connectors between these two only to the "main"-assembly as shown.
http://youtu.be/ZAauES1fKEQ
Message 17 of 23
XuesongBai
Hi Thomas,
Could you please send the video to me by email?
I cannot access youtube in China.
-Xuesong
Message 18 of 23
XuesongBai
Hi Thomas,
I understood what the problem is it.Yes, that is the limitation now.
The first workaround should be as below:
1,Place the assets and connect the assets in the third floor in main layout
2,Drag and drop the assets in main layout into the second floor in model browser
Alternative is that you can place the asset in second floor and then expose the connector on the asset. And then back to the main layout, you can use “Connect” command to connect the assets between second floor and third floor.Finally you can continue to edit the second floor to place the other assets.
-Xuesong
Message 19 of 23
chillme1
I am following this thread with GREAT interest as I am newbie and will soon be tacking similar, multi-story manufacturing challenges.
Is there any possiblity of sharing instructional videos on this topic from thread via a company e-mail for my personal usage only?
Let me know how to receive media via e-mail securely with the originator and / or Autodesk support person here.
I am just starting a 3D model of a multi-story (up to 6 floors) food chemical (powdered solids and liquid) manufacturing plant.
Along with FDSP, we use CADWorx Plant & P&ID Professional for piping.
Thanks for your comments,
Clint Hill
Message 20 of 23
XuesongBai
Hi Clint,
Nice to meet you here.
Geneally I like share the big media stuff in Autodesk 360.So you can share your email here or contact me directly via [email protected].
By the way,I am also interested in your piping tool. I want to learn how connect FDS layout to the piping system.
-Xuesong
