Factory Asset is not inserted
rkrauseH2BUE
Observer Observer
rkrauseH2BUE
Observer
Observer
Hi together,
i just created a factory layout in Inventor with FDU and wanted to drop some factory assets from the library. When i download the Assets, everything looks normal. I then drag it to the layout and it appears transparent on the ground, but when i click to position it nothing happens. In the bottom left the command just says "choose Component". Does anybody has a solution, how i can fix that, so that i can drag&drop factory assets again.
ruben
Logos_Atum
Hello Ruben,
did you make sure the project file includes the library paths?
Dogs aren´t flammable.
rkrauseH2BUE
Observer
Observer
yes, it works for some assets, but not for all, even if they are in the same library
Logos_Atum
The assets you chose did download correctly? And can you share your FDS version? There might be an official faq.
Thanks!
