Enable or disabe Connector Class Properties / active or not
gert-leonvanlier
Message 1 of 8
gert-leonvanlier
I think I already know the answer, but just to be sure: Is it possible to enable or disable Connector Class Properties?
I want to connect two conveyors. In situation A the width needs to be identical, in situation B they must not be identical.
I read on having multiple connectors in the same place, turning these connectors on or off, but that means I have to connect to right connector or need to enable the right connector before connecting.
Thanks.
Replies (7)
Message 2 of 8
TAR_Loki
I think you are right.
But thee is also another way you can use.
You can work with a variant at your asset.
So can choose the variant at the asset, before you take it from the library.
The only thing is, that you have to create this variants for different connectors at you asset and publis them again.
Message 3 of 8
liqinomickey
Hi There,
May I ask, how is situation A / B defined in this layout? You would like 1 type of asset to fit in both situation A and B? How would the asset in situation A knows it is in situation A?
Thank you,
Mickey
Mickey Li
Product Manager
ACS Docs Platform feature team
Autodesk, Inc.
Message 4 of 8
gert-leonvanlier
I tell the conveyor in which situation it is. Let say the infeed side needs to be identical, in that case a connector called "Connector1A" is unsuppressed and connector "Connector1B" is suppressed. If Connector1A is connected with a connector called "Connector2A" the connector class is active. At the outfeed it is the same thing, but then the connectors are Connnector2A and Connector2B. That means you can have the following options:
  • 1A - 2A --> connector class active
  • 1A - 2B --> connector class not active
  • 1B - 2B --> connector class not active
  • 1B- 2A --> connector class not active
This is how I have it working right now, separate for infeed and outfeed, but not differentiating between infeed and outfeed could also be an option if that suffices.
Message 5 of 8
liqinomickey
Hi
I uploaded a video. HIH
Mickey
Mickey Li
Product Manager
Autodesk, Inc.
Message 6 of 8
gert-leonvanlier
Thank you! That is exactly how I have it working right now. Thumbs up for you video. 👍
Message 7 of 8
reggie.mostert
Hej, Thanks for the helpfull video!
Though i have a little different situation/problem i hope is possible to solve.
Let's say i have 2 assets, Asset1 and Asset2.
Asset1 is a machine with 2 rails in it, both rails have their own connectors. ConnectorA and connectorB.
Asset2 is a rail that runs from machine to machine. Both sides the same ConnectorC
We want the rails of different lines in different colors. Doing this with parameters/iLogic and via connectorclasses.
Situation:
When i place Asset1, i can choose different color per rail in the asset. When i connect Asset2 with ConnectorC to ConnectorA, i want the color the rail of ConnectorA has, been transfered to Asset2.
But when i place another Asset2 and connect it's ConnectorC to Asset1's ConnectorB, i want that the new asset gets the color of ConnectorB.
Is this possible? And if so how?
Message 8 of 8
liqinomickey
Hi @reggie.mostert ,
 Sure it is possible. Have the following code in your connectorclass file.
    <RailColor family_type="normal" connector_name="ConnectorA" value_source="parameter">RailColorA</RailColor>
    <RailColor family_type="normal" connector_name="ConnectorB" value_source="Parameter">RailColorB</RailColor>
    <RailColor family_type="normal" connector_name="ConnectorC" value_source="Parameter">RailColor</RailColor>
And when defining Asset1, Use parameter "RailColorA" to define the color of the rail of ConnectorA;
When defining Asset2, Use parameter "RailColor" to define the color of the rail.
HIH
Mickey Li
Product Manager
Autodesk, Inc.
