Edited Landing surface floor constraint in Factory reverts value to 0
JalarsenRV66Z
JalarsenRV66Z
Hi all,
I have a question regarding factory design- when I create an asset with a landing surface, and place this in a factory layout, it receives the floor constraint if placed onto a floor:
as it should do, landing surface determines this. But if I edit this value, if for example I want to elevate the part 500 mm from the ground floor, like this:
It does elevate like I want it to, but if I move the part it or constrains it to some thing it resets to 0 again, how do I stop this from happening?
See attached video.
Thanks in advance.
Josh_Hudson97
Hi @JalarsenRV66Z,
Have you tied setting your landing plane using a key parameter in the factory properties?
This is our workflow and it works well 😃
So when defining the landing plane set the value to your <Parameter Value> and when defending the asset in your layout you can set it in the factory properties
HANG_HEIGHT is set by the user in the factory props
I hope I understood your question correctly and this helps you guys out 😀
If I've helped you out drop the post a like, if I've given you a solution mark as solved. It's us, 'The community' that makes this place work 😄
TAR_Loki
Yes, the best way is to create an surface with a distance and the name Landing.
After you had created the parameter for the distance, you can set this to 0 before offering the asset to the library.
Now you can use this parameter everytime at your drawing to change the distance of your asset.
