Counting a parameter up via Connector Class
mk92
mk92
Hi all,
I have an asset which changes its appearance depending on the amount of supports attached to it. So my question is:
Is there a possibility to count a parameter up via connector class? So if the first support is attached change from 0 to 1, and with the second support counting from 1 to 2 and so on.
Kind regards.
XuesongBai
Hi Marco,
That should be possible.
For example, there are connectors on the asset. C1, C2,C3,C4. Each connector mapping a specific parameter. P1,P2,P3,P4. The default vaule is 0.
So if C1 ,C2 and C3 are consumed, P1=1, P2=1 and P3=1 but C4 is not consumed, P4=0. Finally you can calculate them in iLogic. The total supports is 3.
Hope that will be working for you.
-Xuesong
Please mark as a solution if somehow I got it right.
mk92
But all these Parameter have to be KeyParameters and are visible in the FDS in my Asset Parameters right? I cant pass hidden parameters via ConnectorClasses, also in FDS 2018?
But you are right, this could be a solution for me, not pretty, but could work.
SveinnIngi
Hi Xuesong,
This is interesting. Can you explain to me in more detail how this mapping is done? Maybe send me a .ipt or something. I would like to try this out but I'm quite lost. Thanks.
Best regards,
Sveinn
