chained objects
chained objects
s.may8X5PK
Message 1 of 13
chained objects
s.may8X5PK
Hello everybody,
I currently have the problem with sketches (see video)
Replies (12)
Message 2 of 13
liqinomickey
Sure @s.may8X5PK ,
I can see the problem, it seems the asset chain generated backwards and went the other direction. Is this issue happenning to other assemblies and schetchs as well? happenning with other asset chain as well?
Would you please zip up the asset library, and pack and go of the assembly(layout) and send to
mickey.liATautodesk.com
Thank you.
Mickey Li
Product Manager
ACS Docs Platform feature team
Message 3 of 13
s.may8X5PK
Hi @liqinomickey
sorry now I can currently no longer adjust the error 😞
Message 4 of 13
liqinomickey
Hi  @s.may8X5PK
That's strange, if you ever reproduce again, you can always send to my email of the data set. Thank you.
And you can mark status as solved for this thread. Thank you.
Mickey
Mickey Li
Product Manager
Message 5 of 13
S_May
@liqinomickey
hier ist auch das Problem. nach der Skizze werden die verketten Objekte abgesetzt, nach dem Absetzen ist die Skizze kaputt und die Objekt sitzen wo anders.
Ich kann die Skizze nicht mehr finden und nachbearbeiten!
Die Sizze war vorhe komplett bestimmt im Inventor!
Message 6 of 13
S_May
@liqinomickey
Hilfe es eilt .... 😞
Message 7 of 13
liqinomickey
Hi @S_May ,
Sorry, it was a long holiday in China last week till now. Sorry for the late response.
After the sketch is converted to a chain of assets, it will be deleted by design. But judging by the snapshot, (red line were added after taking the snapshot correct?) the position of the assets indeed were incorrect.
Would you please try in a newly created layout, draw a sketch and convert to assets? see if it still reproduce. If so, would you please zip up the asset chain/Straight segment/Turn segement assets folder and the iam of the layout and send to me ? Thank you.
Mickey Li
Product Manager
Message 8 of 13
S_May
Hi @liqinomickey
I've emailed them all
Message 9 of 13
stefanie_you
Hi @S_May
Is the asset chain you're using the system asset chain "Belt Conveyor(chain)" ?
Stefanie You
Software QA Engineer
Factory Design team
Message 10 of 13
S_May
Message 11 of 13
liqinomickey
Hi @S_May ,
Was the parameter changed in properties palette after the asset chain conversion? the width of the conveyor is 425 instead of 710, and 710 is the standard width of system asset belt conveyor.
If the parameter was not changed manually after conversion. It is possible that we were using a chain asset not from the system asset.
Could you please record a screencast starting before we draw the sketch and through out to after the conversion? Thank you
Mickey Li
Product Manager
Message 12 of 13
liqinomickey
Hi @S_May ,
Were you still reproducing this issue? Thank you.
Mickey
Mickey Li
Product Manager
Message 13 of 13
S_May
Hallo zusammen,
ich konnte das Problem nicht mehr nachstellen.
