We would like to be able to use the NumPad for entering sizes AND use constraints in our services. However, if one uses the NumPad, it is exactly as if one used the number Pad on their Keyboard.
The Right Side of the NumPad should be set up to choose the size, even if it is on constraint.
The challenge is with a 1" sized pipe. If one hits the (1) on the NumPad, you will get a 10" constraint. Hit (1) again, and it goes to 12", etc...it steps through each constraint that starts with a (1).
When I hit the (1) on the NumPad, I need it to choose the 1" pipe PERIOD.
