Show only
Search instead for
Some way to export the same data (and breakout) that is available in the Item Reports is vital to going paperless in the shop - whether through Export > Item Data Fields or Export > Ancillary Data.
I've since found that you can get a combined LS/SS tie rod list report by using the Linear Nesting reports...you just need to suppress all the nesting info. This however does not address the "Export" as you pointed out.
