TieRod Cutlist
TieRod Cutlist
Like the ability to create a Tierod cutlist report NOT broken down by LS/SS.  Item report only gives you access to LL/SS seperately but not aggregate.
Ancillary report gives you total lengths, not a combined total by size and length.
3 Comments
Some way to export the same data (and breakout) that is available in the Item Reports is vital to going paperless in the shop - whether through Export > Item Data Fields or Export > Ancillary Data.
I've since found that you can get a combined LS/SS tie rod list report by using the Linear Nesting reports...you just need to suppress all the nesting info. This however does not address the "Export" as you pointed out.
aaron.tw
Status changed to: Gathering Support
