Stretchable Saddle (CID 2875)
Need 2875 to be able to be stretched and work with "optimize lengths".
Make a new pattern if needed but saddles of a fixed length require an added weld typically. If someone's laze and doesn't manually calculate and adjust the branch length, it's going to be a minimum $100 bill each time in labor.
Think of the waste this creates.
3 Comments
gmurphy
Also I belive your talking about reporting the full length of the Saddle also not to the center of the Pipe it's attached to.
gmurphy
Oh can we also see the Saddle get a connector assigned of some sort so we can generate a Fish mouth weld!!
dyoung
Weld quantification....another good add.  You should be able to get a rough length calculating it but yes, it would be nice if reporting the actual length of pipe was also possible. Not an issue for small bore but large bore can really add up.
