Revit Support for Fabrication Hanger Patterns
It would be very helpful to have Fabrication Hanger Patterns supported In Revit for vertical piping. As it is now, only the Slide Options Type of pattern 838 is supported in Revit on Vertical Pipe. The geometry of this pattern is not correct for many things this pattern can be used for, hence all the other Options Types that work in CADmep, the vertical pipe needs support just as horizontal pipe does. Some things you could use this pattern for would include sleeves and water stop rings as well and the intended use as a pipe support.
