ESTmep customised worksheet
Our estimators need the ability to create a pdf record copy of a trace estimated drawing.
This needs to show custom data fields from our job info front sheet plus cost breakdown summary / irp's.
We would like to display breakdown / irp's in the column to the right of the the worksheet (see example attached)
Currently it is not possible to display / add this information.
Also, we need greater graphical control over the graphic displayed in the layout.
It has not been possible to pring the graphics in a dark line weight as we require.
Cheers
Dave
5 Comments
andy.robins
andy.robins
Hi Dave
Investigate the LOS command in ESTmep, let us know what fields are missing from the "Job Viewer Report" print object
Takeoff info we would be looking to include in the job viewer report to include quantities as per:-
Duct
o Sqm
o Lin mtr
o Install Hours for areas / rooms / zones / section / service / systems (custom item data field)
- Same for pipe
We were wondering if a pre-configured report (irp) could simply be displayed in an area on the LOS?
So reports we have set up & can print individually can also be displayed on the LOS.
jazpearson
We can't read the headings unfortunately. Could you please list out the print objects that you'd require, please?
We would like to be able to include the following on the Worksheet with the ability to show itemised & also grand totals:-
DUCT GUAGE
DUCT AREA (WITH SEAMS)
DUCT LINEAR MTRS
DUCT WEIGHT
DUCT END SIZE
SUPPORT QTY
DUCT INSTALL TIME
DUCT SUPPORT INSTALL TIME
DUCT FAB TIME
DUCT COST
DUCT INSTALL COST
PIPE LINEAR MTRS
PIPE DIA
PIPE FITTING QTY
PIPE FITTING COST
PIPE COST
PIPE HAMGER QTY
PIPE HANGER COSTS
PIPE INSTALL TIME
PIPE INSTALL COST.
Basically anything which can be reported in an IRP should me made available to report out on a worksheet.
Having the ability to simply display a configured report on the worksheet would be the ideal approach.
