[CF-4839]_Improve the 'Insert Part' feature so I don't have to use a toggle btn
If you feel its painful, having to toggle the 'Insert Part' ribbon button when wanting to cut parts into straights, please give this a vote.
Thanks.
4 Comments
Personally, I'd rather prioritize things that cant be done currently (there's a lot of them) over things that can but are just annoying or require a couple extra picks.
John3Dpipe
Every click takes time and when I have to add a click every time I place a fitting on the end of a pipe it adds many clicks during a typical workday. I would MUCH prefer that it go back to as it was in 2021 where I can choose to activate the insert part button and it is not always activated.
Time consuming and aggravating, please revise this.
John3Dpipe
I'm here again to stress the importance of revising this tool. For me it's a time-consuming delay every time I place a fitting. More often than not I'm not cutting a fitting in I'm placing a fitting. When placing several fittings, the number of clicks is exponential, and the time and aggravation adds up. This tool as it is presently, is a drain on my productivity. Most of my current projects are 2021-2023, it would be greatly appreciated if you could update all versions with a better version of this tool.
manzilottiQDPSN
The latest version of this tool has severely impacted mine and my coworkers’ productivity. Our work flow has been developed around being able place parts at the ends of runs way more often than cutting into straights, especially in high traffic mechanical rooms, It has even caused some parts with one connector to not be usable at all. The option to choose a default method for placing a part should be implemented to insure optimal use for all.
