Button Code asignment
When building a service template and dragging in the ITM in to initially populate the Button Code/ Key Sequence with the Itm ALIAS!!
3 Comments
wtucker0301
gmurphy,
 Lets leave alias alone (as that has other uses) and suggest a data field for button code on every item maybe under Alias Field. And have that populate the button code when we drag it in. With that it could be powerfull for revdesign. What do you think?
gmurphy
I like the idea for a dedicated field to have the button code import in.  Need it to fill in the Button Code and the Key Sequence.
aaron.tw
Status changed to: Gathering Support
