BPOOL, Spool.INI - Option to close all .dwgs as they are spooled.
The closeDWG setting in the spool.ini only applies to the last spool that is processed. We often spool 25+ spools at a time, which often locks or crashes autocad. Suggested options:
1) create bspool, so that when it runs, it runs in the background and never makes itself the current window. it's impossible to work in AutoCAD when it is spool, but also hard to work in any other application as AutoCAD will make itself the active window repeatedly through the process.
2) modify the "closedwg" option to close each drawing as it is spools (before it starts to process the next spool.dwg), currently, when the Closedwg is set to 1, it only closes the very last spool processed. perhaps closing windows as it goes will help to minimize crashes.
2 Comments
andy.robins
is there a way to set the closeDWG in the spool.ini to 1 or 0, without physically opening the SPOOL.INI file?  It would be nice to do from within AutoCAD, but i don't see a check box in the BSPOOL window and/or don't know if there a command that would edit that.
it works great!  but am now thinking about how to offer this to the entire department without them having to physically get into their SPOOL.INI files.
