Title: Alternative Drop-Cutter Algorithm with Angular Clamping, Bridging, and Safe Pivot-on-Spot for 5-Axis Finishing with End Mills
Description:
Currently, when using End Mills or Toroidal tools under a specific lead/lean angle relative to the surface normal on complex 3D surfaces, Autodesk PowerMill’s standard gouge checking algorithm often leads to erratic tool axis behavior. The system continuously micro-adjusts the tilt or forces excessive lifting to maintain perfect mathematical contact, which ruins machine dynamics and surface finish.
We propose implementing an Alternative / Simplified 5-Axis Drive Algorithm designed specifically for practical mold/die machining, based on the following logic:
1. Vector-Driven Drop-Cutter Approach: The system should orient the tool according to the user-defined lead/lean angle relative to the surface normal at the target point, and then drop the tool along this specific vector until the FIRST point of contact occurs anywhere on the tool geometry (bottom, corner radius, or side).
2. Safe Material Remainder Concept: We understand that the center of the tool might "hover" over depressions, leaving unmachined material. In practical mold-making, this is acceptable, as remaining stock will be removed by subsequent rest-machining operations with smaller tools. Preventing gouges and maintaining smooth machine movement is the primary goal here.
3. Angular Clamping (Controlled Tilting Limits): If the initial drop causes a heel/rear-edge collision, the software should allow the user to specify a strict angular range (e.g., between 5° and 15°). The system can dynamically tilt the tool only within these specific boundaries to clear the heel.
4. Non-Plunging Linear Interpolation ("Bridging"): If a collision cannot be resolved within the defined angular limits, the algorithm must NOT force the tool to plunge into the cavity or stutter. Instead, it must bridge the gap by locking the tool axis orientation and moving in a straight linear interpolation line to the next valid point.
5. Safe Pivot-on-Spot & Temporary Bridge Part: When the tool reaches the next valid point where the rear-edge collision is no longer present, it needs to pivot/rotate back to its standard lead/lean orientation. To prevent the rear edge of the cutter from plunging into the stock left under the bridge during this rotation, the software must treat the bridge line as a temporary part geometry. The tool must perform a controlled pivot-on-spot, ensuring that neither the bottom nor the rear edge violates this temporary "bridge" boundary.
Benefit:
This alternative algorithm would provide an incredibly smooth, fluid 5-axis toolpath for flat and toroidal cutters on wavy, complex surfaces. It eliminates frantic tool axis oscillations, protects the machine's CNC drives, extends tool life, and delivers a predictable surface finish, leaving cleanly defined rest-material for subsequent operations.
