Setting Variable Dimensions to Custom Solids/Geometry
mkrsmanovic
mkrsmanovic
I'm working on a project that needs to fabricate a significant number of novel pipe supports in the field. The supports are geometrically very, very different from standard supports, including the standard patterns in CADmep database.
I am able to model these parts in multiple Autodesk product. I am able to import them, convert them to solids, set up connections and snap points and save to project folder in CADmep. But I cannot figure out for the life of me how to set parametric dimensions that would enable me to build product lists. My imported solids have no editable dimensions, and I cannot figure out a way to define them. What I want to do is set up a series of dimensional parameters the same way I would do it in other CAD software, that would allow me to change the geometry by inputting a different value for a dimension. I would then use these to set up a Product List in CADmep.
I've been browsing obscure documentation pages, forums, videos, etc. for days and this is one bit of info I am unable to figure out. I hope the answer is not that this is not possible to do. I don't mind doing any work that is required to make this work, I just cannot find the documentation for it. Does anyone know the way to pull this off?
sbowen1J4TT6
Community Visitor
Community Visitor
Hi mkrsmanovic, did you find out how to do this? I am in a very similar situation where I've created a part but now need to make a catalog of it with varying dimensions.
grgroupbangalore_seo
It can be hard to set variable dimensions when working with custom solids in CADmep at first. The most important thing is to clearly define your parameters and connect them to your geometry limits. After you set it up, you can change the sizes on the fly without having to rebuild the model. This saves time and keeps your design consistent across similar parts.
