Pipework information not showing when hovering over service
Hello
When I hover over pipework containment and circular duct work only shows an item number and no information. On rectangular duct work it shows item number, size, level etc.  How do I get other services to show the same information?
donald.kunath
Hello @Anonymous
Thank you for your post and welcome to the community!
Just to be sure we are on the same page, what Fabrication program are you using (CADmep?) and what version, you can find out what version you are running by typing appinfo into the command line.  Please send me a screen shot of this information.
In addition to the app information can you also please send me screenshots of the what you are seeing with your duct work and not on your pipework containment or circular duct?
Thank you and I look forward to your thoughts!
Donald Kunath
Technical Support Specialist
Installation and Licensing Forum | Revit Ideas board
Hi
Further to your email these are the items you have asked for along with a snapshot.
Using Fabrication CADmep 2019
Kind Regards
Mark Brackett
donald.kunath
Hi @Anonymous
Thank you for your reply, unfortunately I was not able to view the snapshots you sent my way.  While you locate and send those screen shots my way I have some items I would like you to test.
Note: the fist step is essential for CADmep to display the default Item information correctly. When testing the ToolTip the CADmep attacher should be removed from the item.
1. Go to AutoCAD Options > Display tab >  Windows Elements section - disable the option "Show rollover ToolTips"
If still not displaying:
2. Try toggling Dynamic Input (F12)
3. Issue the FORCETOOLTIP command
Please give the above a try and report back to me your findings.
If you found my post solved your problem, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
donald.kunath
Hi @Anonymous
I hope you are doing well and making lots of progress on your project.
I wanted to check in and see if you had a chance to review the suggestion from my last forum post, or if you have any additional questions for me?
If you found my previous post solved your problem, please click on "Accept Solution" to help others with similar questions.
Donald Kunath
Hi Donald
Further to your email response below. Have had the problem again recently.
Just to let you know
Item2. Try toggling Dynamic Input (F12)
Worked.
Many Thanks
Mark
@donald.kunath wrote:
Hi @Anonymous
Wayne_Harris
Using CADmep 2024, I am not able to see the spool number information in the rollover tool tips box. Is there a way to add custom properties that you want to see when rolling over/hovering on items?
Confirmed and no change
No change
No change
