Invalid Dimension on Copper Pipe
Message 1 of 11
When placing a copper tube, say from the autodesk library (Pipe-B88-CU-L(PE)), then stretching the pipe, doing a fill, anything I will get the waringing "Dimension B is Invalid (0.4375)".  The warning has the heading Pattern: - 1/4 and I have to click ok through the entire product list.  This can happen with only placing pipe on its own and trying to stretch it.  I have had this problem with earlier versions where I'd turn off the insulation.  Not the case in this instance.  All insualation and insulation specs are off and not set.  I am using CADmep 2016 SP-1 and AutoCAD MEP 2016 with the hotfix's installed.  I've tried a new drawing and still get the same occurance.
Is anyone else having this problem?  If so, is there a fix other than getting rid of product lists and calc the same pipe size?
Replies (10)
Message 2 of 11
Mike, Does this happen in a new blank drawing?, With Insulation on or off?
Message 3 of 11
Yeah, it happens in a new blank drawing with insulation off... I've also noticed that it only does it for the sizes 1" and below.
Message 4 of 11
Check the couplings. That was the cause of an issue we had a while back.
Message 5 of 11
Just checked the couplings, they seem to be ok. I can place a length of pipe and then stretch it to a shorter length (without any fittings or couplings) and it still goes through all the patter invalid dimensions.
Message 6 of 11
Would you mind posting a small dwg that has this issue?
Message 7 of 11
Attached is a sample drawing of a piece of 3/4" copper pipe
Message 8 of 11
MOatman
When investigating your issue I discovered I had the same issue.  I excluded every fitting in the service until the error stopped.  I found a flange that I made with an invalid dimension that was causing the error.  The invalid dimension wasn't an issue until it was used in 2016 software.
Message 9 of 11
Awesome! Don't have 16 here to work with.
Message 10 of 11
Thank you moatman and Backnblack, I went through and excluded fittings until I found the problem with mine as well... it ended up being a rod coupling in my hanger tab with a bad calc
Message 11 of 11
Thanks for the help. The solder joint was the problem for me. Worked fine in 2014, not working in 2016.
