Files taking long time to open
mikeabraham1986
Observer Observer
mikeabraham1986
Observer
Observer
I have two files with services drawn up in them, and in the last couple of days, the files take over 20 mins to open. The files are 7MB & 27MB, and have roughly 7 2d xrefs overlaid, but cant think why it would take so long to open.
Can anyone help?
Due to the fact that you have seven 2D xrefs, i am wondering if this is an issue i had years ago where the progress bar would constantly say "scanning the drawing". With the new interface it could potentially be the same problem, but without the old visual characteristic. Verify that your "SHOWLAYERUSAGE" variable is set to zero.
If it isn't that then I am not sure and i would have to suggest opening them with the "RECOVER" command and/or open them up (wait the 20 minutes) and once open use the "AECTOACAD" command; just hit enter throught the prompts. This will create an identical drawing prefixed with ACAD. I am not real sure what it does, but I have fixed a number of drawings by doing that. Then there is of course the option to just Copy/Paste all the objects into a brand new drawing and see if that drawing recieves the issue.
try all that... may have some luck...
mikeabraham1986
Observer
Observer
Thanks for that however, it  didnt solve it.
The SHOWLAYERUSAGE was at 0, and when it eventually opened I copied it all out into a new file, but that is takling the same time to open as well.
I tried the RECOVER method,with no luck.
I deleted all non- FABMEP items and purged and audited, but it is still taking an age to open.
Cant think of what else it could be
