Export from Est MEP to Excell
Hi
I am currently trying to Export data from Est MEP to Excell and previously managed to do this , I then set up the Data I wanted to Export more accuratley and  when I exported and imported into Excell , some but not all are imported.
Any ideas ?
Regards Gary......
bknapton
If you exported to a text file, try opening that and see if all the data is there.  If not, check the report to make sure the fields you wanted are checked to output.
