Compatibility issue with one of these Fabrication products and the others.
SefullaEmini
SefullaEmini
Which Products are not compatible with the following?
Advance Steel_ AutoCAD_ AutoCAD_ Map 3D_ AutoCAD MEP_ Fabrication CADmep Fabrication CAMduct Fabrication ESTmep_ Factory Design Utilities_ Navisworks_Revit_Advanced Steel.
Which has to be removed?
I am thinking AutoCAD MEP
craigjonnson
I'm not very clear on what you are asking.... If its which products from the below list can be integrated into each other and what doesnt? Then:
AutoCAD Advance Steel - (AutoCAD, AutoCAD, Map 3D, AutoCAD MEP, Fabrication CADmep, Factory Design Utilities) Can be imported into  Navisworks & Revit_Advanced Steel.
AutoCAD - As per and Inc Advance Steel.
AutoCAD Map 3D - As per and Inc Advance Steel.
AutoCAD MEP - As per and Inc Advance Steel.
Fabrication CADmep - As per and Inc Advance Steel.
Fabrication CAMduct - CADMEP & ESTMEP only through MAJ Export.
Fabrication ESTmep - CADMEP & CAMDuct only through MAJ Export.
Factory Design Utilities - As per and Inc Advance Steel.
Navisworks - Can import most file types. CAMDuct and ESTMEP excluded.
Revit_Advanced Steel - Can import DWG, SAT, etc. File exports but functionality of Revit Advanced Steel would be lost.
