Can we Develop Add-Ins like Revit for CADMEP
Message 1 of 12
Dear Guys,
Guys if any one have any idea that can we develop Add-Ins like Revit in CADMEP. If yes please guide me to do or give me reference link so that i can try.
Replies (11)
Message 2 of 12
nathan.chapman
BholaDev-
I would check out the Fabricaiton SDK doc.  It has a very similar api then Revit.  Attached is the Fabricaiton 2017 sdk document.
Nate
Nathan Chapman
Production Manager at General Heating and Air Conditioning
Revit Architecture Certified Professional
Revit MEP Mechanical Certified Professional
Revit MEP Electrical Certified Professional
DynaFabrication Package Author
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDOS button.
Message 3 of 12
Dear Nathan,
Thank you. This help me lot. Sorry for delay acceptance.
Message 4 of 12
Dear Nathan,
With the help of Fabrication.chm. I am able to create Plugin for ESTmep and CAMduct. But while going to create Add-Ins for CADmep i need some assistance. If possible please provide me step by step procedure for CADmep.
Message 5 of 12
nathan.chapman
Look in this location on your computer C:\Program Files\Autodesk\Fabrication 2016\SDK.  There is an example that will show you what you are looking for.
Nathan Chapman
Message 6 of 12
Dear Nathan,
Thank you for reply. Still i facing some issue. Not able to run Sample Fabrication Application. I attached a video please review and guide me where i did mistake.
While i am trying to load FabricationApI.dll through Netload in Cad. It stop at loading AeciRibbonUiApi.. . It also heepn while run fabrication sample.
Message 7 of 12
nathan.chapman
Put those files in this location C:\Program Files\Autodesk\ApplicationPlugins.  That should solve your problem.
Nathan Chapman
Message 8 of 12
Which files FabricationApI.dll? and what is the use of FabricatioSample.Addin?
Message 9 of 12
nathan.chapman
You want the whole folder.
This is whats in the folder FabricationSample.bundle
Nathan Chapman
Message 10 of 12
Dear Nathan,
Very thank to you. Now i am getting Icon of fabrication Sample but while click on Icon getting below error message.
i am searching some where find that need to reinstall . Can you please suggest me why this is happen . I also open project in visual studio and rebuild dll then again same thing happen.
So i give Full permission to folder FabricationSample.bundle  but still same thing happen.
Message 11 of 12
Dear i am really so sorry. i often disturb you. But i am new to learn Fabrication API Development.
Approach 2:
I am trying to trace where is the problem...
Step1:
Step 2:
Step 3:
Step 4:
Message 12 of 12
Dear Nathan,
i got the problem solved. i missed to load CADmep "CADmep20_1x64.arx". Thanks for your support
