CamDuct Marking/Etching Issues
caleb.voigt
Observer Observer
caleb.voigt
Observer
Observer
Hey everyone, I am using CamDuct 2022 to draw and nest for my CNC Hypertherm table. Everything works great with it except the marking/etching. After the parts are etched and cut, the etching will be offset +x 1" and +y 1" and be offset from where I need the markings to be. I can't find any settings to change this. Anyone have any ideas on how to fix this? Thanks in advance!
phendricks
Hey Caleb,
If you're able to, can you upload a NC file for the machine? I work for an Autodesk partner that can adjust settings for post processors and can see what may be causing the offset. It might be "built in" and see the etching tool as a secondary action that has a certain "distance" from the main cutting head, and adding that distance into the code.
Patrick
