CAMduct Graphical Images Not Printing
Message 1 of 15
Hi, we're new to this so please excuse the terminology.
We have just moved across from a demo of CAMduct where all graphical images were printed from worksheet reports, but now the same reports print without any images. They are showing in the print preview however. We've tried all sorts of settings without success. Can anyone help with this?? Thanks in advance.
Replies (14)
Message 2 of 15
Ok, so it seems that a windows update is responsible for the issues and that removing the KB5000808 & 802 resolves the issue. Has anyone managed to remove these KBs?
Message 3 of 15
Mike_Arcari
I had the same issue
remove the KB5000802 windows update and it should solve the problem
Message 4 of 15
Thanks Mike. 802 doesn’t appear to be installed but 808 is. There is no option to uninstall it from the windows update history, we’ve also tried wusa command prompt but no joy there either.
does anyone know if there are tools that will enable us to remove it?
Message 5 of 15
Mike_Arcari
Hi
If you go to windows update and view update history
there should be an option to uninstall updates at the top of the page
select this and click the update you want to remove
on my home PC it was update KB5000802
on my work PC it was update KB5000808
removing these fixed the issue on both machines
hope that helps
Message 6 of 15
dyoung
Just posted on this the day before...
https://forums.autodesk.com/t5/fabrication-cadmep-forum/critical-alert-windows-update-can-break-fabr...
Darren J. Young
http://www.darrenjyoung.com/
https://www.linkedin.com/in/darrenjyoung/
Message 7 of 15
Thanks everyone for your valued input. We are now back up and running.
It seems that we had an issue with an incomplete update, so having re-installed the major update it then allowed us to remove the offending KBs. Hopefully Microsoft will release a patch in the next few days.
Message 8 of 15
thanks all un installing the last windows update 802 solved the problem
Message 9 of 15
karndt9UQLZ
As per Darren Young's post, rolling back the last update, restarting computer, gave me back the OPUS Print capabilities.
Thank You forum helpers!
Kevin Arndt
Master Mechanical Inc.
Message 10 of 15
windows keep ask to download the update 802 after uninstalling,any solution?
Message 11 of 15
karndt9UQLZ
Install it or let it finish installing it, restart computer, then uninstall it?
Message 12 of 15
sorry but this not helpful
windows will re download the updates
Message 13 of 15
dyoung
Try this....
https://is.gd/eyJjiX
Darren J. Young
Message 14 of 15
matthewweake
I just found this article that will help with those pesky images:
https://knowledge.autodesk.com/support/fabrication-products/troubleshooting/caas/sfdcarticles/sfdcar...
Matthew Weake
[email protected]
+64 9 302 4028
Message 15 of 15
Mike_Arcari
switching of the accurate pattern view fixed the issue for me
your a legend Mathew 😉
