Beveled x Threaded Pipe
douglas_lyle
douglas_lyle
So, very new to Fabricated CADmep.  As I was trying to set everything up, I can't seem to find or figure out how to create a beveled x threaded pipe.  In otherwords, I want to add a thread-o-let (on a coil connection) and tie onto a welded header without a coupling in between.  Seems i would be able to add a a bvXthrd pipe, but I can't figure out what is the best way to do this...
-DOUGLAS
jhoward-HOB
Not that this is an easy topic to truly explain, but this could be handled very elegantly with the right set of connectors.
If you think about a "weld joint" there are technically 2 connectors on it. So, you can have a joints specifically designed to "complete" the connectivity of deviant scenarios.
