Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
304 stainless steel welded plain end pipe fitting, help
Message 1 of 11
does anyone know how or where i can upload 304 stainless steel welded plain end pipe fittings onto fabrication cad mep 2017, i am needing that for my drawings.
Replies (10)
Message 2 of 11
CraigFarsh
Hi cgivens95AK6
You say you would like to upload, is this content something that you have created yourself that you want to distribute?
Craig
Craig Farish
Quality Analyst | Product Owner | Experience Designer
Message 3 of 11
it is content that i would like to upload for future drawing purposes
Message 4 of 11
CraigFarsh
Hi @Anonymous
Ok, so i'm assuming that you have a .dwg where you have created the content and you want to incorporate the content into your master configuration?
Craig Farish
Message 5 of 11
I'm just wondering if someone knows of a place where i can download the content like for example victaulic has uploading available for their products.
Message 6 of 11
CraigFarsh
Hi @Anonymous
Apologies, I mis-understood the issue. You might have more success if you change the subject to something more along the lines of "Looking for 304 grade welded stainless imperial content"
From reading your posts it sounds as though you are wanting to upload your own content.
FYI, we have a content website http://www.building3dcontent.com/ but we only have 304/316 welded content for the metric configurations.
Craig Farish
Message 7 of 11
i am aware of that website and the piping that they have i tried to upload and it was not in dwg format and they only have tubes of 304. i need 304 pipe fittings in dwg format.
Message 8 of 11
mmccallisterF5JMW
Observer
Observer
Is there a chance that stainless steel pipe and fittings will be added to the web page. I know when TSI maintained the data bases they had just about anything you would need for content. I also need Vogt valves.
Message 9 of 11
CraigFarsh
Hi @mmccallisterF5JMW
Autodesk are not actively developing fabrication content. I recommend reaching out to Applied Software who may be able to supply the content that you require.
Regards
Craig Farish
Message 10 of 11
These guys will built you whatever you need cheaper than you can do it yourself.
https://www.virtualbuildingsupply.net/
Message 11 of 11
Where can we find the imperial content web site
