Solved by dan.banach. Go to Solution.
Folder-Level Permissions are being turned on for Autodesk Education accounts in batches, and the goal is to have them all turned on the week of Feb. 6. If you need it turned on faster, please fill out this form
Sign up for Fusion Folder Permissions
Once it is turned on, you can follow these steps to create a Folder-Level Permission project.
Note: Currently you CAN’T convert an existing project to a Folder-Level project. A Folder-Level project must be created from scratch.
I believe I've followed the correct steps to create a folder-level project in my team. I see the project in Fusion Team, but not in Fusion 360 itself. I'm an admin on the project. I'm sure I'm missing something, but what? I've invited several students to the project as read-only and they can see and use the project files.
Hi benton81,
In Fusion 360's Data Panel, when you create a new Project, does the tooltip say ""Create Folder-Level Project"? If not, you're access may not be turned on yet. We're in the process of turning this functionality on for all Autodesk Education accounts.
-Dan
That was it - the New Project button in Fusion only allows "Closed Project". I created the folder-level project in Fusion Team. Thanks!
