That's not the correct answer. Everyone seems to guess alot at autodesk. I'd like real answers to my dev errors in the validation process
This topic was split from a larger topic by @LeoWarren-EDU to maintain clarity of the issue being discussed.
Title edited by @LeoWarren-EDU to include the relevant product version.
Original title: Re:Error while trying to activate autocad 2021
Solved by LeoWarren-EDU. Go to Solution.
I need to understand how the app is using edge or chrome. It does look like IE a bit. But activation happens from inside your executable from autodesk. Does the default browser even matter then? We can't validate any license to use them, our organization is crippled, and support is uselessvfor 2 days through chat. I need a dev or someone who understands tge token process of registration and why its failing. Thanks
@davelFS9M2 wrote:I need to understand how the app is using edge or chrome. It does look like IE a bit. But activation happens from inside your executable from autodesk...
No one here is Autodesk, or from the development team at AutoCAD. And they are not ever likely to see it to respond in any way.
So... what can we end users (just like you) help with if you did not like the answers so far?
If you are facing licensing issues... Here are ways to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/account/manage/use/support#:~:text=com/plans.-,Contact%20support,-S...
Hi @davelFS9M2,
Which version of AutoCAD are you trying to deploy?
I can currently see two cases open, and I've escalated them to our tier 2 Education Support team, who will be able to provide the most appropriate support.
I hope this helps,
Update: This case was resolved by our Educational support team, therefore I am marking this response as the solution for the benefit of users who come across this topic in the future.
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Platform & Operations Manager
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
Hi @davelFS9M2,
I hope this helps,
Leo Warren
