I downloaded Revit 2022 for a class (the professor specifies that it MUST be Revit 2022), and I successfully installed it. However, when I launch Revit, a Windows command window begins to repeatedly open and close. It does this endlessly when I have Revit open, making it functionally impossible to run Revit. I clicked on one before it was able to close itself, and attached an image of what the command window says. Any help on how to fix this? I already uninstalled and reinstalled Revit, only to have the same issue. I need Revit to work soon so I can begin my classwork.
Solved by mdavis22569. Go to Solution.
Solved by slukesX5VSY. Go to Solution.
You have post open already about it:
This isn't educational either.
Hi @slukesX5VSY,
Have you reviewed this article and followed the steps outlined?
Please let me know if you have any further issues or questions,
Please 'Like' posts that are helpful. If a post answers your question then feel free to click the 'Mark as Solution'
Leo Warren
Community Manager - Students & Educators
Are you a student? Come join our Student & Educator Community! | Education Knowledge Base | Rules and Etiquette
Solution found on YouTube:
You didn't see that it was the same in the link I shared on your other post
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/SQLDUMPER-EXE-wind...
