Hi there,
i wanted to talk about a strange problem i run into every time i use the design blocks.
What happens is that the design block utility complains about double net classes names instead of merging them.
We generally use only "default" "Power"and "GND"in all our designs and it would be great if the nets would just be connected when using a block that has the same net names.
Instead it refuses to paste the block and i first have to rename the class to something else, paste the block, then rename the nets back.
I attached a file that illustrates the problem.
Solved by jorge_garcia. Go to Solution.
Actually, that makes a lot of sense now...
So the slot number is the important part, and then the name...ok..i get it.
So it is important that we keep the order and name consistent...Eagle is unable to sort the name by name first.
0 default
1 GND
2 power
will not work with
0 default
1 power
2 GND
for example...
All right, thanks a lot 🙂
