- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am designing a single layer board, and the routing has split my GND polygon into two separate areas.
I have added a 0 ohm resistor, to act as a jumper and restore continuity between the two GND planes - but Eagle PCB continues to show an airwire between the two. Is there some way that I can modify my 0 ohm resistor component so that Eagle PCB knows that it provides a connection between the two ends?
Link copied
