Hello @Anonymous,
I hope you're doing well. Wow, V4.0 that was at least 15 years ago(if not more). You could try these ULPs that are up on our website.
http://eagle.autodesk.com/eagle/ulp?utf8=%E2%9C%93&q%5Btitle_or_author_or_description_cont%5D=dsn&button=However, at this point I do sincerely feel you would be better served by an update. If you don't do PCB design every day, that's cool, just get a monthly subscription whenever you need to work on a PCB. The cost is very reasonable.
To
@hanakp_BUT point, I think the biggest problem Autorouters have going against them are people's expections for them. Even the best constraint based Autorouters can't take every design consideration into effect. If Autorouters could do as good a job as a pro designer, we would all be out of jobs. An autorouter is a tool and part of leveraging it appropriately is understanding it's limitations and what it's good at. For example, EAGLE's autorouter is very useful for dropping pads straight to power planes. That's several hours of tedious boring work that can be easily avoided. Additionally, if you particular circuit has critical nets route those manually first and then let the autorouter go to town on the stuff that isn't critical. In those situations were it is used judiciously it can legitimately save you work, but if you are going to let it run free then yeah the results will be suboptimal.
Best Regards,
Jorge Garcia
Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
