I am using Eagle 9.6.2 premium. When I highlight a polygon the components and track under that polygon become invisible. See the screen shots below:
PCB before GND signal is highlighted
PCB When GND signal is highlighted
What can be the reason?
I am using Eagle PCB from its 3.55 version onwards (when CadSoft USA owned it). Note that in old eagle the above mentioned issue is not there. See the screenshots
Old Eagle PCB before GND signal is highlighted
Old Eagle PCB when GND signal is highlighted. Tracks under the polygon is partially visible
Solved by jorge_garcia. Go to Solution.
Hi @thomasjude,
I hope you're doing well. I sent you a reply to your email. As I get more information I'll continue to post here.
Let me know if there's anything else I can do for you.
Best Regards,
jorge.garcia recommend changing the fill style of the layers from solid to something else. He said "You can adjust the fill style in the display command by double clicking on a layer"
It worked. But a slight issue is that polygons as well as the tracks change the style. But not a big issue.
