Thermals in Polyigons - TH and SM
grahamUTKMN
grahamUTKMN
Is there a way to set a polygon pour so that TH parts have thermal relief but SM parts don't?
G
jorge_garcia
Hello @grahamUTKMN,
I hope you're doing well. This is not possible, I'm actually a little concerned about this request since typically it's more critical for SMDs to have thermal relief than TH parts.
What's your use case?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
grahamUTKMN
Hi Jorge,
Not at all. With modern manufacturing techniques there's no need usually to connect SM pads via a thermal relief to the copper pour - it just makes the pour less worthwhile.
I only want the thermal relief on the TH pads that will have parts hand soldered into them.
In software I've used previously I've had general control over deciding on thermal relief for SM vs TH pads - but then I could select pads individually to over-rule the global setting.
Please can I request this as a feature?
Graham
jorge_garcia
Hello @grahamUTKMN,
I hope you're doing well. Feature has been requested.
Best Regards,
Jorge Garcia
grahamUTKMN
