The Inversion a text - inverted text/label.
kaktus
kaktus
Hello, to the community. (and staff)
Recently a beautiful specimen of electronics has fallen into my hands.
When I saw the labels, I fell in love. 🤣
Pay attention to how the labels were made.
The text is cut from the background. This looks great and is much more readable than a simple text.
I'd like to be able to make these inscriptions on my PCB.
I tried to find some post on the forum about this topic. However, it was not successful. 🙄
I doubt I'd be the first to make this up.
However, I have to ask if anyone knows how to make such labels
Yura.Ivanov.VLuki
<если Вы хотите вырезать ТЕКСТ в области полигона - поместите ТЕКСТ на слой Restrict>
if you want to cut out the TEXT in the field of the ground - place the TEXT on layer Restrict
kaktus
Hi.
This solution is so simple that it is obvious.
It is not without reason that it is said that the most difficult thing to come up with is simple stuff.
Thank you for bringing me back to earth.
Yura.Ivanov.VLuki
<если Вы хотите чёрный ТЕКСТ на белом фоне - нарисуйте прямоугольник на слое Place (будет белый, если шелкографию заказываете белой) поместите ТЕКСТ на пользовательский слой (>100), не забудьте сделать САМjob, укажите производителю печатных плат, что этот слой шелкографии нужно сделать черной краской>
if you want the black TEXT on a white background - draw a rectangle on Place layer (will be white if you order silk-screen printing white) place the TEXT on the user layer (> 100), do not forget to make CAMjob, specify to the producer of printed circuit boards that this layer of silk-screen printing needs to be made black paint
kaktus
When I forced myself to make an intellectual effort, I remembered that I had already made such an inscription in the form of holes in the layer of copper (1 or 16). 😂
But I still don't know how to do it in layer 25 or 26 (tNames bNames). I think we would have to define a Restrict layer for them.
Do you have any idea
Yura.Ivanov.VLuki
@kaktus  написал (-а):
<Нет. Представьте процесс изготовления PBC.
Нанесение надписей (шелкография) производится краской с ограничением минимального штриха (толщина (задаем в % (RATIO))) и высоты знаков (SIZE).
Не знаю как можно сделать вырезы, но думаю будет выглядеть плохо (наплывы) и плохо читаться.
Пером пишем знаки, но обвести знак заливкой пера трудно.
Проще заказать светлую маску платы и темную шелкографию.>
No. Present PBC production process.
Drawing inscriptions (silk-screen printing) is made by paint with restriction of the minimum stroke (thickness (we set in % (RATIO))) and heights of signs (SIZE).
I do not know as it is possible to make cuts, but I think will look bad (flows) and it is bad to be read.
We write with a feather signs, but it is difficult to lead round the sign filling of a feather.
It is simpler to order a light mask of a payment and dark silk-screen printing.
