I have a following footprint:
The top part is just a wire/line on copper layer, so in manufacturing it works well. You can see it better here:
So effectively a pad is placed over a line. The goal here is to have an exposed trace that is routable, and I wanted to avoid having to do it directly in layout for many reasons - so I just made a part.
Now this obviously makes Eagle not happy:
and it makes sense, as there clearly is an overlap. My question: is there a better way to have an exposed copper connected to a pad in footprint editor that would not trigger overlap errors?
I know I can change DRCs, but they are there for a good reason. I know I can just ignore the errors (which is not as I need to keep track of the number to make sure there isn’t a ‘real’ overlap somewhere else) but I just want to make sure that I’m not missing some feature of the footprint editor.
Thanks.
Solved by rachaelATWH4. Go to Solution.
You would be better to do the additional copper as a polygon which extends far enough into the pad to surround the centre of the pad. This is called a custom pad shape in EAGLE. Doing so will mean that you don't get the DRC errors.
Best Regards,
Rachael
That worked, thanks! Although I was hoping I could get away with replacing just the last part with a polygon (well, a polygon that backtracks on itself so it’s a line) but now the polygon overlaps with a line further up (and I have a lot of them).
But that is only because I did wrong to start with 🙂 Thanks again.
