Smash or Reposition attributes tool issue
Hi everybody! Hope you're doing well!
I just passed to Eagle V9.3.1 Premium (before I was on 7.7.0) and I had issue with the "Reposition Attributes or Smash" tool.
For jumper pins, I usually use a part name JPx (JP1 for example) and for the jumper who should be goes on the jumper pins I use JPX.Y (J1.1 for example)
Like this in the BOM, I know that the kind of jumper I need and where it should go... (In this example on JP1)
So the issue is that in EAGLE V9.3.1, the name of my jumper JP1.1, no problem
The issue appears when I tried to smash (reposition attributes) it.
See the picture below who explain the issue....
I can press OK and the position of NAME attribute is out of range.
I tried to rename the jumper to JP1-1 or JP1*1. But it seems not accept other character as letter or number.
If someone has already this issue or a trick to get around the problem
