Simulation output: PPerror: syntax error
Where is the error and why does show this message?
Note: No ".plot", ".print", or ".fourier" lines; no simulations run
This is my netlist:
* SpiceNetList
* Exported from black_box.sch at 20/7/2019 4:01 μμ
* EAGLE Version 9.4.2 Copyright (c) 1988-2019 Autodesk, Inc.
.TEMP=25.0
* --------- .OPTIONS ---------
.OPTIONS ABSTOL=1e-12 GMIN=1e-12 PIVREL=1e-3 ITL1=100 ITL2=50 PIVTOL=1e-13 RELTOL=1e-3 VNTOL=1e-6 CHGTOL=1e-15 ITL4=10 METHOD=TRAP SRCSTEPS=0 TRTOL=7 NODE
* --------- .PARAMS ---------
* --------- devices ---------
C_C7 +5V 0 100uF
D_D2 N_2 N_3 1N4004
C_C11 0 N_2 100nF
D_D5 -12V 0 1N4004
C_C3 N_5 0 4700uF
C_C9 0 -12V 100uF
D_D1 N_3 N_5 1N4004
C_C5 0 N_2 4700uF
D_D3 +12V N_5 1N4004
C_C1 N_5 0 4700uF
D_LED1 N_7 0 DMOD
D_D4 N_2 -12V 1N4004
C_C6 0 N_2 4700uF
R_R2 N_8 +12V 1K
X_IC3 +5V 0 +12V LM7805
R_R1 N_7 +5V 1K
C_C10 N_5 0 100nF
D_LED3 N_8 0 DMOD
C_C8 +12V 0 100uF
R_R3 N_9 0 1K
X_IC2 N_2 0 -12V LM7912
V_V1 N_3 DC 0V AC 0V SIN(0 12V 50Hz 0 0)
C_C4 0 N_2 4700uF
D_D6 0 +12V 1N4004
C_C2 N_5 0 4700uF
D_LED2 N_9 -12V DMOD
X_IC1 N_5 0 +12V LM7812
* --------- models ---------
* model file: C:/Users/Στέλιος/Documents/EAGLE/projects/Black_Box/LM7812.mdl
.SUBCKT LM7812 1 2 3
QT6 23 10 2 Q_NPN 0.1
QT7 5 4 10 Q_NPN 0.1
QT5 7 6 5 Q_NPN 0.1
QT1 1 9 8 Q_NPN 0.1
QT3 11 8 7 Q_NPN 0.1
QT2 11 13 12 Q_NPN 0.1
QT17 1 15 14 Q_NPN 10
C2 10 23 4P
R16 12 5 500
R12 16 2 12.1K
QT18 17 23 16 Q_NPN 0.1
D1 18 19 D_D
R11 20 21 850
R5 22 3 100
QT14 24 18 2 Q_NPN 0.1
R21 6 2 2.67K
R20 3 6 5.22K
DZ2 25 26 D_5V1
R19 1 26 16K
R18 14 3 250M
R17 25 14 380
R15 25 15 1.62K
QT16 1 20 15 Q_NPN 1
QT15 2 24 21 Q_PNP 0.1
*OFF
R14 21 24 4K
C1 27 24 20P
R13 19 2 4K
QT13 24 27 18 Q_NPN 0.1
QT12 20 25 22 Q_NPN 1
*OFF
QT11 20 28 2 Q_NPN 0.1
*OFF
QT10 20 11 1 Q_PNP 0.1
R10 17 27 16.5K
R9 5 4 1.9K
R8 4 23 26
R7 10 2 1.2K
R6 29 2 1K
QT9 11 11 1 Q_PNP 0.1
QT8 27 16 29 Q_NPN 0.1
QT4 15 6 17 Q_NPN 0.1
DZ1 2 9 D_5V6
R4 1 9 80K
R3 28 2 830
R2 13 28 4.97K
R1 8 13 7K
.MODEL D_5V1 D( IS=10F N=1.16 BV=5.1 IBV=0.5M CJ0 = 1P TT = 10p )
.MODEL D_5V6 D( IS=10F N=1.16 BV=5.6 IBV=5U CJ0 = 1P TT = 10p )
.MODEL Q_NPN NPN( IS=10F NF=1.16 NR=1.16 BF=80 CJC=1P CJE=2P
+ TF=10P TR=1N )
.MODEL Q_PNP PNP( IS=10F NF=1.16 NR=1.16 BF=80 CJC=1P CJE=2P
+ TF=10P TR=1N )
.MODEL D_D D( IS=1F N=1.16 CJ0 = 1P TT = 10p )
.ENDS LM7812
* model file: C:/Users/Στέλιος/Documents/EAGLE/projects/Black_Box/LM7912.mdl
* This is a copy of the LM7905 from regulators.lib.
* R22 changed from 500 -> 7500
.SUBCKT LM7912 1 2 3
DD4 4 5 D_6V3_0
DD2 6 2 D_3V9_0
DD1 7 2 D_4V7_0
DD3 8 3 D_6V3_0
C2 9 10 5P
C1 2 9 15P
QTU15 10 9 3 Q_PNP_0 1.000
R17 11 12 4.2K
QTU22 3 10 13 Q_NPN_0 3.000
R18 8 5 15.65K
R20 13 14 1K
R19 4 14 75
QTU31 12 11 4 Q_NPN_1 1.000
R16 15 1 160
R24 16 1 1.8K
C3 17 1 10P
QTU30 18 12 15 Q_NPN_1 1.000
QTU29 10 16 1 Q_NPN_1 1.000
R15 19 1 400
QTU28 10 20 19 Q_NPN_1 1.000
R14 21 1 200
QTU27 17 20 21 Q_NPN_1 1.000
R11 22 23 1K
R10 24 25 1K
QTU19 18 27 26 Q_NPN_1 1.000
R9 2 18 7.1K
QTU8 16 18 2 Q_PNP_0 1.000
QTU7 28 18 2 Q_PNP_0 1.000
QTU6 18 18 2 Q_PNP_0 1.000
QTU5 11 29 2 Q_PNP_0 1.000
QTU4 20 29 2 Q_PNP_0 1.000
QTU3 1 29 2 Q_PNP_0 1.000
QTU2 1 29 2 Q_PNP_0 1.000
R13 28 1 400
R12 30 1 400
QTU18 29 29 31 Q_NPN_1 1.000
QTU1 29 29 2 Q_PNP_0 1.000
R6 31 32 6.5K
R7 32 27 5.6K
R8 27 26 950
QTU10 33 6 26 Q_PNP_0 1.000
QTU17 34 35 33 Q_PNP_0 1.000
R5 36 1 2K
QTU24 34 34 36 Q_NPN_1 1.000
R1 37 6 6.3K
R2 37 38 670
R3 38 35 550
QTU9 38 35 6 Q_PNP_0 1.000
R4 39 1 2K
QTU23 35 34 39 Q_NPN_1 1.000
QTU16 1 7 35 Q_PNP_0 1.000
JT1 7 1 1 J_2N3458_N
QTU14 3 17 23 Q_PNP_0 1.000
QTU13 17 17 23 Q_PNP_0 1.000
QTU12 17 17 25 Q_PNP_0 1.000
QTU11 9 17 25 Q_PNP_0 1.000
QTU32 3 13 14 Q_NPN_2 10.000
QTU26 9 20 28 Q_NPN_1 1.000
QTU25 20 20 30 Q_NPN_1 1.000
QTU21 2 40 22 Q_NPN_1 1.000
QTU20 2 37 24 Q_NPN_1 1.000
R21 2 40 4.29K
R22 40 3 7500
R23 14 1 500M
.MODEL J_2N3458_N NJF( VTO=-3.05 BETA=699.53U LAMBDA=6M RD=1 RS=1
+ CGD=2.81P CGS=2.91P M=227.1M PB=500M IS=114.41F
+ VTOTC=-2.5M BETATCE=-500M KF=0 AF=1 )
.MODEL D_6V3_0 D( IS=10F N=1.24 BV=6.3 IBV=1M CJ0 = 1P TT = 10p )
.MODEL D_3V9_0 D( IS=10F N=1.24 BV=3.9 IBV=1M CJ0 = 1P TT = 10p )
.MODEL D_4V7_0 D( IS=10F N=1.24 BV=4.7 IBV=1M CJ0 = 1P TT = 10p )
.MODEL Q_PNP_0 PNP( IS=10F NF=1.04 NR=1.04 BF=50 CJC=1P CJE=2P
+ TF=10P TR=1N VAF=45)
.MODEL Q_NPN_0 NPN( IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P
+ TF=10P TR=1N VAF=90)
.MODEL Q_NPN_1 NPN( IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P
.MODEL Q_NPN_2 NPN( IS=10F NF=1.04 NR=1.04 BF=100 CJC=1P CJE=2P
.ENDS LM7912
* model file: C:/Users/Στέλιος/Documents/EAGLE/projects/Black_Box/1N4004.mdl
*src=1N4004;DI_1N4004;Diodes;Si; 400V 1.00A 3.00us Diodes, Inc. diode
.MODEL 1N4004 D ( IS=76.9p RS=42.0m BV=400 IBV=5.00u
+ CJO=39.8p M=0.333 N=1.45 TT=4.32u )
* model file: C:/Users/Στέλιος/Documents/EAGLE/projects/Black_Box/LM7805.mdl
* LM7805 model.
.SUBCKT LM7805 1 2 3
* In GND Out
QT5 7 6 5 Q_NPN 0.1
QT1 1 9 8 Q_NPN 0.1
C2 10 23 4P
R16 12 5 500
R12 16 2 12.1K
D1 18 19 D_D
R11 20 21 850
R5 22 3 100
R21 6 2 2.67K
R20 3 6 640
DZ2 25 26 D_5V1
R19 1 26 16K
R18 14 3 250M
R17 25 14 380
R15 25 15 1.62K
*OFF
R14 21 24 4K
C1 27 24 20P
R13 19 2 4K
*OFF
*OFF
R10 17 27 16.5K
R9 5 4 1.9K
R8 4 23 26
R7 10 2 1.2K
R6 29 2 1K
DZ1 2 9 D_5V6
R4 1 9 80K
R3 28 2 830
R2 13 28 4.97K
R1 8 13 7K
+ TF=10P TR=1N )
+ TF=10P TR=1N )
.ENDS LM7805
* model file: C:/Users/Στέλιος/Documents/EAGLE/projects/Black_Box/DMOD.mdl
* Autodesk EAGLE - Spice Model File
* Date: 9/17/17
* basic diode intrinsic model
.MODEL DMOD D
* --------- simulation ---------
.control
set filetype=ascii
TRAN 1e-5 0.005 0 1e-5
write black_box.sch.sim V(N_2) V(N_5) V(-12V) V(+5V) V(+12V) I(V_V1)
.endc
.END
No one?
What is PPerror:syntax error???
jorge_garcia
Hi @Anonymous,
The issue with your file is likely the greek characters. Try storing your models in a location where you don't have the greek characters. EAGLE's SPICE engine is very picky about character formatting.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
ben_vonk
I had recently the same error. One of my nodes was named 0.5_VDD. After renaming it to HALF_SVDD it was solved and the data was stored correctly. So it seems that some node names give problems in storing the simulation data.
