It segfaults with the following in console
./eagle-8.4.1/eagle: /home/user/eagle-8.4.1/lib/libdbus-1.so.3: no version information available (required by /lib64/libavahi-client.so.3) Installed Qt WebEngine locales directory not found at location /home/user/eagle-8.4.1/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /home/user/eagle-8.4.1/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. [1120/145637:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine ICU data not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... Installed Qt WebEngine locales directory not found at location /home/eagle/Qt/5.6/gcc_64/translations/qtwebengine_locales. Trying application directory... Qt WebEngine locales directory not found at location /home/user/eagle-8.4.1/libexec/qtwebengine_locales. Trying fallback directory... Translations MAY NOT not be correct. Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64/resources. Trying parent directory... Qt WebEngine resources not found at /home/eagle/Qt/5.6/gcc_64. Trying application directory... [1120/145637:WARNING:resource_bundle.cc(291)] locale_file_path.empty() for locale qt.network.ssl: QSslSocket: cannot resolve CRYPTO_num_locks qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_id_callback qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_locking_callback qt.network.ssl: QSslSocket: cannot resolve ERR_free_strings qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_init qt.network.ssl: QSslSocket: cannot resolve sk_new_null qt.network.ssl: QSslSocket: cannot resolve sk_push qt.network.ssl: QSslSocket: cannot resolve sk_free qt.network.ssl: QSslSocket: cannot resolve sk_num qt.network.ssl: QSslSocket: cannot resolve sk_pop_free qt.network.ssl: QSslSocket: cannot resolve sk_value qt.network.ssl: QSslSocket: cannot resolve SSL_library_init qt.network.ssl: QSslSocket: cannot resolve SSL_load_error_strings qt.network.ssl: QSslSocket: cannot resolve SSL_get_ex_new_index qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method qt.network.ssl: QSslSocket: cannot resolve SSLv23_client_method qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method qt.network.ssl: QSslSocket: cannot resolve SSLv23_server_method qt.network.ssl: QSslSocket: cannot resolve X509_STORE_CTX_get_chain qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf qt.network.ssl: QSslSocket: cannot resolve SSLeay qt.network.ssl: QSslSocket: cannot resolve SSLeay_version qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_num_locks qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_set_id_callback qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback qt.network.ssl: QSslSocket: cannot call unresolved function SSL_library_init qt.network.ssl: QSslSocket: cannot call unresolved function SSLv23_client_method qt.network.ssl: QSslSocket: cannot call unresolved function sk_num Segmentation fault (core dumped)
I ran it with gdb, backtrace is
Thread 1 "eagle" received signal SIGSEGV, Segmentation fault. 0x00007ffff72f2a03 in ?? () from /home/user/eagle-8.4.1/lib/libQt5Network.so.5 Missing separate debuginfos, use: dnf debuginfo-install alsa-lib-1.1.4.1-1.fc26.x86_64 avahi-libs-0.6.32-7.fc26.x86_64 bzip2-libs-1.0.6-22.fc26.x86_64 cups-libs-2.2.2-7.fc26.x86_64 expat-2.2.4-1.fc26.x86_64 flac-libs-1.3.2-2.fc26.x86_64 fontconfig-2.12.6-4.fc26.x86_64 freetype-2.7.1-9.fc26.x86_64 glib2-2.52.3-2.fc26.x86_64 gmp-6.1.2-4.fc26.x86_64 gnutls-3.5.16-1.fc26.x86_64 gsm-1.0.17-1.fc26.x86_64 keyutils-libs-1.5.10-1.fc26.x86_64 krb5-libs-1.15.2-4.fc26.x86_64 libICE-1.0.9-9.fc26.x86_64 libSM-1.2.2-5.fc26.x86_64 libX11-1.6.5-2.fc26.x86_64 libXau-1.0.8-7.fc26.x86_64 libXrandr-1.5.1-2.fc26.x86_64 libXxf86vm-1.1.4-4.fc26.x86_64 libasyncns-0.8-11.fc26.x86_64 libcap-2.25-5.fc26.x86_64 libcom_err-1.43.4-2.fc26.x86_64 libcrypt-nss-2.25-12.fc26.x86_64 libdrm-2.4.88-1.fc26.x86_64 libffi-3.1-12.fc26.x86_64 libgcc-7.2.1-2.fc26.x86_64 libgcrypt-1.7.9-1.fc26.x86_64 libglvnd-1.0.0-1.fc26.x86_64 libglvnd-glx-1.0.0-1.fc26.x86_64 libgpg-error-1.25-2.fc26.x86_64 libidn2-2.0.4-1.fc26.x86_64 libogg-1.3.2-6.fc26.x86_64 libpciaccess-0.13.4-4.fc26.x86_64 libpng-1.6.28-2.fc26.x86_64 libselinux-2.6-7.fc26.x86_64 libsndfile-1.0.28-6.fc26.x86_64 libstdc++-7.2.1-2.fc26.x86_64 libtasn1-4.12-1.fc26.x86_64 libunistring-0.9.7-1.fc26.x86_64 libuuid-2.30.2-1.fc26.x86_64 libvorbis-1.3.5-2.fc26.x86_64 libxcb-1.12-3.fc26.x86_64 libxshmfence-1.2-4.fc26.x86_64 lz4-libs-1.8.0-1.fc26.x86_64 mesa-dri-drivers-17.2.4-2.fc26.x86_64 mesa-libGL-17.2.4-2.fc26.x86_64 nettle-3.3-2.fc26.x86_64 nspr-4.17.0-1.fc26.x86_64 nss-3.33.0-1.0.fc26.x86_64 nss-mdns-0.10-18.fc26.x86_64 nss-softokn-3.33.0-1.1.fc26.x86_64 nss-softokn-freebl-3.33.0-1.1.fc26.x86_64 nss-util-3.33.0-1.0.fc26.x86_64 openssl-devel-1.1.0f-7.fc26.x86_64 p11-kit-0.23.9-2.fc26.x86_64 p11-kit-trust-0.23.9-2.fc26.x86_64 pciutils-libs-3.5.5-1.fc26.x86_64 pcre-8.41-1.fc26.x86_64 pulseaudio-libs-11.1-6.fc26.x86_64 sqlite-libs-3.20.1-1.fc26.x86_64 systemd-libs-233-7.fc26.x86_64 tcp_wrappers-libs-7.6-85.fc26.x86_64 zlib-1.2.11-2.fc26.x86_64 (gdb) bt #0 0x00007ffff72f2a03 in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #1 0x00007ffff72f3704 in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #2 0x00007ffff72e03f5 in QSslCertificate::fromData(QByteArray const&, QSsl::EncodingFormat) () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #3 0x00007ffff72e2282 in QSslCertificate::fromPath(QString const&, QSsl::EncodingFormat, QRegExp::PatternSyntax) () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #4 0x00007ffff72fcc94 in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #5 0x00007ffff72fd0d4 in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #6 0x00007ffff72e0325 in QSslCertificate::QSslCertificate(QByteArray const&, QSsl::EncodingFormat) () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #7 0x00007ffff72e30a9 in QSslConfiguration::QSslConfiguration() () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #8 0x00007ffff727ae3c in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #9 0x00007ffff7282b12 in () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #10 0x00007ffff725f389 in QNetworkAccessManager::createRequest(QNetworkAccessManager::Operation, QNetworkRequest const&, QIODevice*) () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #11 0x00007ffff725c824 in QNetworkAccessManager::get(QNetworkRequest const&) () at /home/user/eagle-8.4.1/lib/libQt5Network.so.5 #12 0x0000000000dab6cb in () #13 0x0000000000756b96 in () #14 0x00000000007584d2 in () #15 0x00007fffea4aa88a in __libc_start_main () at /lib64/libc.so.6 #16 0x000000000048515f in () (gdb) quit
Solved by rachaelATWH4. Go to Solution.
Hi Jorge,
This download page https://www.autodesk.com/products/eagle/free-download offers only version 8.4.1 to download.
I rebuilt openssl as described in the link you provided, but still no luck; same issue.
That download page still has only 8.4.1 link.
Yes it would seem it does, somebody else mentioned that on another thread today too, You can download v8.4.3 from here: https://eagle-updates.circuits.io/downloads/latest.html
I'm not sure if the latest version will solve your issue but it's probably best to be working with the latest build to diagnose this issue.
Best Regards,
Rachael
Hi Rachael,
I downloaded 8.4.3 from that page and it worked nicely. Thanks a lot!
