Route wire both at top and bottom layer at the same time?
No aplicable
446 Vistas
2 Respuestas
Mensaje 1 de 3
No aplicable
To double the current handling capacity, I want to run the route at both top and bottom layers.
The solution used to be :
To start routing without an "unrouted wire", enter "route", keep the the Ctrl-button pressed and click on a pin, pad, via or trace.
However this solution no longer work in eagle 9.6.2 . Does anyone know the new way to do it? Thanks in advance.
0 Me gusta
447 Vistas
2 Respuestas
Respuestas (2)
Mensaje 2 de 3
one-of-the-robs
In what way does it "no longer work"? If you mean that Eagle now deletes the original route, then you can turn that off. Look up "Loop removal".
0 Me gusta
Mensaje 3 de 3
No aplicable
I have already tried [SET LOOP_REMOVAL OFF ] . But when i plan the route only the main route show up on the current layer. If i misunderstood your instruction, please comment. Thank you.
0 Me gusta
