Dear team
I got feedback that
the traces between polygon and IC pad is too thin so it cannot handle large current and it's bad for power dissipation.
I'm currently using EAGLE 9.4 on a MacBook Mojave and OSHPark's DRC file.
https://docs.oshpark.com/design-tools/eagle/design-rules-files/
The vendor wants me to make a thick trace like this example layout; the footprint is covered/flooded to the polygon.
The GND pins and the GND pad is connected to the GND polygon.
When I type the ratsnest command, it creates thin traces.
- How can I make the trace between the polygon and the component thicker?
- Additionally, can I ask what is the white square created by the via? What layer generates this diamond shape square?
Solved by rachaelATWH4. Go to Solution.
Solved by jorge_garcia. Go to Solution.
@jorge_garcia wrote:
You can make the change simply, click on one of the outline segments of the polygon and look in the inspector. You'll see a checkbox that says thermals, make it unchecked. Once that's done click Ratsnest and you'll see that the connections to the polygon are all solid, in other words the pads get swallowed up by the polygon.
Alternatively, if thermal relief IS required but the size of the relief connections is required to be larger then change the line width property of the polygon which will in turn adjust the thermal relief size.
Best Regards,
Rachael
Dear Jorge
Deeply appreciate your help.
You are mentioning the orange circled option, right? After I uncheck it,
"pads get swallowed up by the polygon. "
I'm amazed; it seems like the pads are buried into the plain.
One more thing; is there a way to swallow certain pads, not all?
I drew a big GND plain using the polygon command. If I disable the thermal option,
every component connected to the plain becomes swallowed too.
I just want to swallow certain components. Instead of drawing multiple polygons, is there a way to certain components?
Thanks, Rachael.
" but the size of the relief connections is required to be larger "
I think I need this option.
"change the line width property of the polygon which will in turn adjust the thermal relief size"
May I ask which width you are referring to?
