Message 1 of 8
I've configured the "Annular Rings" or "Restrings" in Eagle as follows:
So I expect to get Annular Rings of minimally 0.125mm wide. The DRC Check doesn't generate errors, so everything seems fine.
Unfortunately, my board manufacturer Eurocircuits complains when I insert the Gerber files for analysis:
I wonder how Eurocircuits can detect Annular Rings of 0.075mm?
Note: OAR is abbreviation used by Eurocircuits for "Outer Annular Ring".
I also notice that Eurocircuits doesn't mark all the via's as wrong, only some. There are three possibilities:
- I made a mistake
- Eagle has a bug
- Eurocircuits analysis software has a bug
What do you think?
