I changed the text size of the module name in Eagle once (from 0.8 default), but
I can't figure out how to do it again - it's like there was I slightly more detailed version of the 'Properties' edit box for Module Info - and I know I was able to access it several times - but I can't figure out how to do it again - and I don't see anything in Help that covers this...
Can anyone tell me how to do it, or where in Help it addresses this?
rachaelATWH4
You need to use the SMASH command so the module name text becomes a separately selectable item. You can then change the size of this text.
Best Regards,
Rachael
