Problem exporting to g-code - help need
Message 1 of 8
Hi!
I made a simple pcb in Eagle 9.2.2 free version.
Yesterday I tried to mill my pcb on my GRBL cnc machine, what actually ended up in a very good and nice pcb.
Quickly I realized I made some mistake and my pins not in correct position.
So, the PinNo1 from my UA741 ic is now on PinNo4 when I rotate may pcb and try to set my ic.
I think I should generate my g-code in some mirror orientation or something like that, but I don't know where and what should I check.
For exporting I use the "pcb-gcode™ Gcode Generation Utility Version 3.6.0.4" which made an excellent result g-code for my cnc machine.
Now I try again to generate my g-code but I always get an empty preview windows when I press the "Accept and make my board" in the pcb-gcode plugin.
I have no DRC errors etc.
Everything seems to me be fine, yesterday it worked, today not working.
Questions:
1. How can I fix my pin number orientation so I can engrave with my cnc a TH pcb?
Should I use the mirror option in pcb-gcode plugin or is there other technique how to make the pcb traces?
2. why have I always empty preview windows after I press the "Accept and generate my g-code" button?
Thak you.
Replies (7)
Message 2 of 8
Can somebody check and report does the "pcb-gcode™ Gcode Generation Utility Version 3.6.0.4" is still compatible with  Eagle 9.2.2 version?
I'm really suspicious about that because I think (but can't clearly remember )  does I have the mentioned problem in my first post, from the time when I was updated Eagle from 9.2.0 to 9.2.2.
Thank you.
Message 3 of 8
petergharrison
I can't comment on Rev 3.2.0.4, but I've been using 3.6.2.4 with Eagle 9.2.2 with no problems at all.
Message 4 of 8
I already tried the 3.6.2.4 version and that never finish to generate the gcode.
I have to kill the Eagle process in the task manager otherwise my pc will freeze
and I have to wait over 30min to get it back to life.
It looks like the pcb-gcode plugin runs in such of infinity loop...
Any suggestion about his?
Thanks.
Message 5 of 8
petergharrison
That sounds very similar to a problem I experienced on the earliest of the Rev 8.x.x versions.  I seem to remember that it had to do with the placement of the polygon outline, but the details elude me at the moment I'm afraid.  I know I reverted to Rev 7.7.0 to get meaningful results until upgrades to Rev 8 eventually worked as expected.
Sorry I can't be more specific right now.
Message 6 of 8
Could this lead to a Java version incompatibility?
I have a feeling as my Java vas also updated that time around when this problem happens.
I uninstalled Java and tried to make the gcode but I run into some error msg from pcb-gcode
what was related to the view window and Java.
At the moment I have Java 8 update 191.
I think that could be the problem...
Message 7 of 8
I already revert to an earlier version of Java, the Java 7 but no way to solve the problem.
I out of memory.
Any help/idea I would appreciate.
Thank you.
Message 8 of 8
After several days of investigation, I found a solution on how to solve my problem.
Check this video if you are interested in:
https://www.youtube.com/watch?v=uWVk6uiVJYE&feature=youtu.be
My best regards.
